Коды ошибок системы Motronic (ENG)
Getting the fault codes to appear on the "Check Engine" light.
Early systems.
Early systems (Motronic 1.1 only, I think) flash the fault codes automatically. If the check engine light comes on, leave the key in the On position, but dont start the car. The check engine light will begin to flash the code after about 3 seconds. Each flash is separated by about 1 second. There arent many codes on this system
1 flash......Air flow sensor malfunction.
2 flashes....Oxygen sensor malfunction.
3 flashes....Coolant Temp. malfunction.
4 flashes....Throttle switch malfunction.
Late 1980s systems. Motronic 1.3
The fault codes for these systems will appear on the check engine light when you turn the ignition key to the On position (but dont start it), then: fully depress the accelerator pedal, then fully release it. Repeat the depress,release cycle 5 times fairly quickly, but not too fast. It should be completed in a few seconds. What you are doing here is clicking the wide open throttle switch then the idle switch each 5 times. This signals the Motronic unit to send the fault codes by flashing the Check Engine light. You should see the light flash once then it will start flashing the 4 digit codes. If there are no faults, you should see the 1444 code (and 2444 if you have a 12 cylinder). The codes appear as a series of flashes for each digit. The flashes indicating one digit are about 1 second apart, the next digit appears after a couple second interval. The rest of the fault codes appear in Table 1 below.
The later systems up to 1995 (Motronic 3.x)
The fault codes appear in the same way as for the Motronic 1.x systems listed above, but it is much trickier to get them to appear. The timing with which you turn the key then depress and release the accelerator pedal is much more critical. You have to depress and release the pedal 5 times, rhythmically, but much faster than for the earlier system. It usually takes a few tries to get it right.
The very latest systems (1995 on)
Fault codes are not available through the check engine light.
The following table requires a HTML 3.0 browser! Upgrade your browser if it appears garbled or doesnt look like a table.
This table lists all the fault codes we could find. If anyone has others, please send them to us. The faults listed are for all different models and some of them are not applicable like Fuel Injector 8 on a 6 cylinder car.
Table 1. The Motronic Fault Codes
Malfunctioning System
Fault Code  Comments
DME Control Unit
1211
Air Mass Volume Sensor
1215
Throttle Potentiometer
1216
Output Stage, Group 1
1218
Output Stage, Group 2
1219
EGO(O2) Sensor 1
1221
EGO(O2) Sensor 2
1212
Lambda Control 1
1222
Lambda Control 2
1213
Coolant Temp. Sensor
1223
Intake Air Temp. Sensor
1224
Knock Sensor 1
1225
Knock Sensor 2
1226
Knock Sensor 3
1227
Knock Sensor 4
1228
Battery Voltage DME Main Relay
1231
Throttle Idle Switch
1232
Throttle WOT Switch
1233
Speedometer A Signal
1234
AC Compressor cut off
1237
AC Compressor
1242
Crankshaft Pulse Sensor
1243
Camshaft Sensor
1244
Intervention AEGS
1245
Ignition Secondary Monitor
1247
Fuel Injector 1 (or group 1)
1251
Fuel Injector 2 (or group 2)
1252
Fuel Injector 3
1253
Fuel Injector 4
1254
Fuel Injector 5
1255
Fuel Injector 6
1256
Fuel Injector 7
1257
Fuel Injector 8
1258
Fuel Pump Relay Control
1261
Idle Speed Actuator
1262
Purge Valve
1263
EGO Heater
1264
Fault Lamp (check engine)
1265
VANOS
1266
Air Pump Relay Control
1267
Ignition Coil 1
1271
Ignition Coil 2
1272
Ignition Coil 3
1273
Ignition Coil 4
1274
Ignition Coil 5
1275
Ignition Coil 6
1276
Ignition Coil 7
1277
Ignition Coil 8
1278
Control Unit Memory Supply
1281
Fault Code Memory
1282
Fuel Injector Output Stage
1283
Knock Control test Pulse
1286
No Failures
1444
For 12 cylinder models, there are additional codes for the second Motronic unit. These codes are the same as above, but the first digit (1) is replaced by 2
Table 2. Motronic Processors and EPROMs
Model Year.
Body Style.
Model.
Processor type.
EPROM type.
9/84 - 9/87
E30
325e/es
1802
2732A
88
E30
325
8052
27256
87-88
E30
325i/is/iX
8052
27256
89-91
E30
325i/is/iX
80515
27256
89-91
E30
M3
8051
27128/256
>8/91
E36
325i/is
MCS-96/51
27C256
>9/92
E36
325i/is/ic
MCS-96/51
27C512
93+
E36
M3-Euro
MCS-96/51
27C256
95+
E36
M3
MCS-96/51
27C512
